HELP! 450 Wolverine water problems!
Old Jun 21, 2006 | 12:33 AM
HappywithVForce's Avatar
Default HELP! 450 Wolverine water problems!
When I wash my 06 Wolverine, it will not start again for hours. It acts like it is flodded. The 1st time it happened I cleaned the air filter. It still took awhile to get it going (running the starter too long).
Now I have a pattern, Every time I wash the bike, if I spray water to the left side of the engine. The bike will not start without MUCH effort from the starter. I am worried that a water crossing will strand me out in the middle of nowhere. I think I will contact the dealer. Do any of you have this problem? Is there an easy fix?
Old Jun 21, 2006 | 02:19 AM
crbm16's Avatar
i have never had that problem. It always starts right up after i wash it. I would try and talk to your dealer
Old Jun 21, 2006 | 12:18 PM
jkvette719's Avatar
Mines never done that, only washed it once though and that wasnt very good lol. Yea i would contact them, sounds like something is lose
Old Jun 21, 2006 | 07:19 PM
Roach007's Avatar
Haven't had that problem on mine and I have washed it maybe a dozen times. I would take it back and show the dealer the problem.
Old Jun 21, 2006 | 10:52 PM
OK, thanks. I will take it back and show them. I know it should not be that sensitive to water.
I just wondered if it has happened to anyone else.
Old Jun 22, 2006 | 07:06 PM
Roach007's Avatar
Make sure you let us know what they find...
Old Jun 24, 2006 | 01:03 AM
hondabuster's Avatar
You should be able to handle this one yourself.
Youve got it narrowed down to the left side. Are you using a pressure washer..or garden hose?
Heres something to try,,,have it idleing, and just using a spray bottle of water, start squriting the different connections on the left side. If you find the bad one, and even if you dont...take apart the connections, and dry them completely. Then add some dielectric grease to s each side of the connection, and put them back together.
Dot forget to put some of that on the spark plug and plug boot.
That should waterproof all the electics.
Old Jun 24, 2006 | 10:26 AM
I have just been too busy lately to dig into it. I just use a garden hose and I don't want it to die again before I found the problem. I am going to take it in today (on the way for a weekend at the beach). The dealer said they will hunt it down. It might be there all week though. I'll let you know.
Old Jul 1, 2006 | 11:22 AM
Ok, I have it back. 1st they called me and could not get it to flood like would happen to me. I said I will be there soon to do it. I could not get it to flood either! Their hose had lousy pressure, but it should have flooded! They did not charge anything and said to take it back when it happens again. It will suck to load it on the truck without it running.
Old Aug 6, 2006 | 08:59 PM
JCREESE81's Avatar
I HAVE HAD THIS EXACT SAME PROBLEM WITH MY WOLVERINE. THERE IS A HOSE THAT COMES OFF OF THE CARB AND RUNS UP UNDER THE GAS TANK. IF YOU TAKE YOUR TANK OFF YOU WILL SEE A 1/4" BLACK RUBBER VENT HOSE THAT LAYS ON THE RUBBER MAT UNDER YOUR TANK. WATER IS ALLOWED TO BUILD UP THERE AND IN TURN YOUR CARB SUCKS THE WATER IN. THE BEST SOLUTION I COULD COME UP WITH WAS TO REROUTE THE HOSE TO THE AIRBOX LID. THIS SHOULD SOLVE ALL YOUR PROBLEMS BUT YOU PROBABLY SHOULD FLUSH YOUR CARB BECAUSE IT ALSO TAKES IN DIRT.
Nondem
Feb 22, 2020 12:20 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
