lt 80 no spark how to test coil
Old Jun 24, 2006 | 04:20 PM
Sandhopper2's Avatar
Default lt 80 no spark how to test coil
I need to know how to test the coil / cdi on a 88 LT 80 stock bike
It just quit running took the coil to a shop they said bad , bought another from E Bay and still no workie
can't seem to trust anyone to tell me , so asking here
please help grandson wants to ride again soon
Old Jun 25, 2006 | 11:03 AM
LT80's Avatar
LT80 Expert
Use an ohm meter and check the stator and coil.
Old Jun 25, 2006 | 11:30 AM
thanks , what should the reading be ? how do I find the stator wires ?
thanks
Larry
Old Jun 25, 2006 | 12:50 PM
LT80's Avatar
LT80 Expert
Do a search, the readings were talked about in a previous thread about the same problem or call a dealer for the correct readings.
The stator wires are under the hood. They come up from the motor and plug in. Your interested in the red/black wire (ignition) not the red/white wire (charging). [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jun 25, 2006 | 12:56 PM
tried the search thing and nothing comes up guess I have to wait till dealer is open
thanks
Larry
Old Jun 25, 2006 | 05:39 PM
arshooter's Avatar
I have a similar problem. Eton viper 90 with weak spark. I Ohm'd out the coil and It is in specs. What do I check next? Would it be the CDI OR something else??? Thanks guys...
Old Jun 25, 2006 | 06:09 PM
LT80's Avatar
LT80 Expert
Welcome to the forums arshooter. [img]i/expressions/face-icon-small-smile.gif[/img]
I'd check the stator now.
Old Jun 25, 2006 | 06:14 PM
arshooter's Avatar
Thanks...
Ok. How do I check the Stator?? I don't think I have the specs for that...
Old Jun 26, 2006 | 11:28 AM
ok I tested the coil with ohm meter , from spade tip to spad tip show 4.59M on my meter is that right ? is this coil good ? the one I took off shows open then 22.35M
when I go to test the stator do I ground 1 wire the look for spark with the other as trying starter ?
thanks for your help
Larry
Old Jun 28, 2006 | 11:24 AM
LT80's Avatar
LT80 Expert
Sorry fellas, electronics are not my specialty as there are few problems with them.
You use an ohm meter to check the stator. I do not know the proper restance readings. [img]i/expressions/face-icon-small-sad.gif[/img]
I suggest asking the service dept at your local Zuki dealer.
Chillibean
1) Engine problems..
Sep 5, 2020 04:02 AM
jeepwheelin02
Jul 18, 2020 06:42 PM
Ripinandtearin
Dec 11, 2017 08:06 PM
WesTech
11
Aug 11, 2015 07:55 AM
Ripinandtearin
Jul 19, 2015 08:38 PM
