lt 80 no spark how to test coil
I need to know how to test the coil / cdi on a 88 LT 80 stock bike
It just quit running took the coil to a shop they said bad , bought another from E Bay and still no workie
can't seem to trust anyone to tell me , so asking here
please help grandson wants to ride again soon
Do a search, the readings were talked about in a previous thread about the same problem or call a dealer for the correct readings.
The stator wires are under the hood. They come up from the motor and plug in. Your interested in the red/black wire (ignition) not the red/white wire (charging). [img]i/expressions/face-icon-small-smile.gif[/img]
ok I tested the coil with ohm meter , from spade tip to spad tip show 4.59M on my meter is that right ? is this coil good ? the one I took off shows open then 22.35M
when I go to test the stator do I ground 1 wire the look for spark with the other as trying starter ?
thanks for your help
Larry
Larry
Sorry fellas, electronics are not my specialty as there are few problems with them.
You use an ohm meter to check the stator. I do not know the proper restance readings. [img]i/expressions/face-icon-small-sad.gif[/img]
I suggest asking the service dept at your local Zuki dealer.
WesTech
11
08-11-2015 07:55 AM
