UTE clutch question
Old Jun 26, 2006 | 11:15 PM
ftwflh's Avatar
Default UTE clutch question
When going to bigger tires do you need heavier or lighter weights or just some that have a differant shift point?
Old Jun 27, 2006 | 02:27 PM
Speedwerx's Avatar
Depends some times just a stiffer secondary might do the trick and sometimes we run heavier weights or same weight weights with more tip weight to prevent slipage at wide open. When you say different shift point weights? Do you mean light tip, normal / medium tip. or heavy tips? Other wise as far as I know there really isn't a weigth that allows you to pic a shift point you cankind of control it with the tip or profile of the weight other iwse you would use the seocondary spring or helix to control how fast or slow you wanted to upshift.
Old Jun 27, 2006 | 02:40 PM
PolarisTheOnlyWayOut's Avatar
Well it really depends on a lot of things tho...Size of tire, weight, width all come into effect...if you have a heavier tire you will need the clutch to engage sooner and tighter (also depends on the quad your putting them on)...My 600 has 26" Mudlites and it has a stock clutch...the twin cylinder turns them over fine since its got pleanty of tourque and doesn't allow much slippage on the belt as long as i don't baby the gas..and the tires are light compared to most larger tires...it justs depends on your model
Old Jun 27, 2006 | 06:54 PM
ftwflh's Avatar
You got what I meant but shift point.
I will try a heavier secondary spring and check what weights are in it stock (it is a 97 425 magnum.I belive it is 10WH if so I have a set of 10MBs to try)
Thanks Brad
ghost civic
Jan 15, 2020 07:43 AM
4464
Aug 21, 2015 01:46 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
ghost civic
Jul 15, 2015 10:48 PM
200es
Jul 10, 2015 09:09 AM
