Honda Rubicon Problems
Please help if you can. I have an 02 (I think - 1st year) Honda Rubicon. Has a grand total of 500 miles on it.
Problem is this - Start the atv - starts fine, give it gas, and it will not pull itself. Bogs down, absolutely no power to turn the wheels. Let off the gas, idles fine.
At first I thought it had something to do with the spark plug wires, but have heard it might be a speed sensor or something in the gear shift.
Dropped it off at the dealer, and it happened when I took it off the trailer. After them driving it for three days, the problem did not resurface.
Problem is very intermittent. Sometimes it is when you first start it, sometimes it happens after you drive it for a while.
At this point I have a very expensive hunk of metal in my garage that I can't trust to take out.
Any help would be greatly appreciated.
01 is the first year for the rubbies. Does the dash blink when this happens? if so it is in the computer it thinks it is in neutral, but it is in gear. Shut off and make sure it is in neutral and start this works for a while but it will get worse we have had 6 of them now and only 2 have had this problem both were 01's . the one never had the problem again but the one has went through 3 of the computers . The dealer replaced all of them, but we bought the extended warranty. its not cheap i though it was with the sensor to but the dealer said it was in the computer. I also think it is caused by water. The computer is above the rear wheel.
sounds to me like a angle sensor. Does your dealer know how to check it for codes, what codes did it have in it. every time there is a failer it will store a code. quick way for you to test if it's a angle sensor put in esp and try to shift up to 5th. If it starts to blink most likely that or reinitilize the ecm. That and did the dealer do a oil pressure test?
that angle sensor could be right they just swapped them the third time and if i was useing it like we did i bet it would do it again, it was starting to act up again when we dumped it . it was about 600 but thats what they said that could be on the high side they are pretty proud of oem
Thanks guys, I am going to forward this thread to my dealer to see what they have done. I'll let you know wht I find out.
KimSJoh
14
Jul 18, 2015 07:20 PM
