Nitrous switch help.
Old Jun 29, 2006 | 04:14 PM
Scatterbrain's Avatar
Default Nitrous switch help.
Im adding a micro switch for the nitrous on the throttle. Ive got a switch like vipers mounted the same way. The button is working fine but I cant get the micro to click the solinoid. Continuity is good on the micro. Ive got it connected the same way as the push button.... nothing. Bridging between the post on the relay.........nothing. Plug the push button switch back in....... click. What am I mising here? Im not electrically inclined. Help![img]i/expressions/face-icon-small-happy.gif[/img]
Old Jun 29, 2006 | 04:17 PM
OregonDunePatrol's Avatar
How many electrical connections does the micro switch have?
Old Jun 29, 2006 | 04:20 PM
If you have a switch where there are TWO connectors for wires, then thats easy. Thats called a Single pole, sigle throw switch. There are switches with Single Pole, double throw, with a total of three terminals. Two of those are usually grounds. So, two grounds wont make it work. Usually, choose the two outside terminals and make your connection to them.
Old Jun 29, 2006 | 04:29 PM
It has 3 connection. I just tried the two out side posts...nothing. Why wont it click it when bridged between the post on the relay? But will click if the stock switch is plugged in?
Old Jun 29, 2006 | 04:31 PM
Is there a ground coming off the stock switch. I only remember two wires coming from the push button
Old Jun 29, 2006 | 04:46 PM
Im such a dumba$$ sometimes[img]i/expressions/face-icon-small-disgusted.gif[/img][img]i/expressions/face-icon-small-blush.gif[/img] There has to be power going to the switch. then to the relay. Ive gotten in a hurry. Thanks Marky
Old Jun 29, 2006 | 04:59 PM
Ya the switch should be powered from the relay then to the switch, then back to the relay - at least thats what I remember - Dang it! I tried to forget all of that! LOL Just Kidding!
Old Jun 29, 2006 | 07:25 PM
sandbomber's Avatar
Any info on the switch yet Marky?
mbkirk
Aug 14, 2015 08:20 PM
user493
Aug 13, 2015 12:54 PM
Hatrackr
1) Engine problems..
Aug 11, 2015 09:03 PM
WILLLANE8302
Aug 7, 2015 08:24 AM
randycraft24c
Aug 5, 2015 02:50 PM
