Possible to remove clutch without airwrench
Old Jul 1, 2006 | 12:32 PM
JBL's Avatar
JBL
Default Possible to remove clutch without airwrench
I'd like to work on my clutch myself to get it dialed in just right. Recap with those who've already helped. Alphasports 90 with 54mm,120jet,UNI filter, Technigas pipe, Red torsion springs, 30gm rollers, unknown clutch springs. Quad hauls all the way to top speed, but the lag is about 3 seconds.
I want to work on the springs myself to dial it in and just get immediate grab. Any suggestions on removing the clutch without an air wrench is greatly appreciated.
Old Jul 1, 2006 | 12:49 PM
newnick's Avatar
I did it once, the first time. It's kinda hard to hold tight enough. I think I used a screwdriver wedged between the variator and case up front and I can't remember what I did in the back. I would try to get my hands on a impact if I were you because it would be easy to tear something up the way I did it before. If you had a large band wrench for like a oil filter, to hold everything that might work. I had the same lag problem as you last year with a similar setup. You may try going lighter with the rollers if the belt will still carry out to the edge of front pully or you might have to lighten your clutch shoes while still using the heavier clutch springs.
Old Jul 2, 2006 | 12:18 PM
LT80's Avatar
LT80 Expert
I've used a big set of channel locks.
Old Jul 2, 2006 | 02:28 PM
cvc42's Avatar
Are the threads backwards?? I have to remove my stator.
Thanks
Old Jul 3, 2006 | 10:25 AM
LT80's Avatar
LT80 Expert
right hand thread.
Old Jul 3, 2006 | 11:29 AM
sssduane's Avatar
If you have an air compressor, impacts are fairly cheap. Or you can try going to harbor frieght and buying an electric for cheap.
Anyways, this is a reason to buy tools, take advantage of it.
Old Jul 4, 2006 | 01:37 AM
JBL's Avatar
JBL
SSSDUANE, Thanks as usual for the tip. dont own a compressor and didnt even know they had electric impact wrenches gonna get one very soon. No time for working on the clutch now. Im Headed to Pismo on the July 5. I'll let you know how the quad handled the dunes.
Old Jul 4, 2006 | 01:58 AM
yellowrider250ex's Avatar
would a break-over wreench work
ghost civic
Jan 15, 2020 07:43 AM
merryman
Jan 19, 2016 04:29 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
ghost civic
Jul 15, 2015 10:48 PM
200es
Jul 10, 2015 09:09 AM
