Simple wiring HELP! PLEASE
Old Jul 2, 2006 | 04:18 PM
matrx's Avatar
Default Simple wiring HELP! PLEASE
Ok, on my 93' Fourtrax 300 the wiring harness is gone to %$@#. So I am seeking help to find the simplest way to get the ignition coil to fire. Running a wire from the battery straight to the coil will not work ( because it will burn out the coil). I am gonna try to run a wire from the green wire on the voltage regulator, but i wont now if this will work because I first have to replace the regulator. I also dont know what the black wire with the white stripe goes to or what its there for (it obviously isnt the ground wire because I have another wire that is screwed into the frame).
Any help or suggestions are GREATLY APPRECIATED!
Old Jul 2, 2006 | 11:22 PM
hondabuster's Avatar
Your best bet, is find a service manual, itll have the wiring diagram in it.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
400H0
10
Aug 20, 2015 07:34 PM
frostphase
Aug 19, 2015 07:11 PM
DeFox500
Jul 26, 2015 06:32 PM
Schneider
Jul 24, 2015 05:05 PM
