Radiator Drain plug issues.
Old Jul 6, 2006 | 03:47 PM
madmatt1971's Avatar
Default Radiator Drain plug issues.
Has anyone messed with their radiator drain plug. If so do you all know what size and thead pitch it has. I'm trying to find a brass replacement for the plastic POS installed. I can't get it tight enough to stop if from driping. This all happened after draining the Radiator. I'd like to get the part before I re-drain my coolant system so I don't tie up my gradge for a day or two whil I rack down the part. Thanks.
Old Jul 7, 2006 | 01:59 PM
Anyone??? It's leaking and I don't want to get a new OE plug to have it leak again in the future.
Old Jul 7, 2006 | 06:02 PM
gates59's Avatar
I have never tried to take that off before because just that reason. I always remove the hose instead. Did you try some plumbing tape on it. Might help.
Old Jul 7, 2006 | 09:48 PM
I should have know also but I though it might be like the ABS ones in car radiators. So at this point I've got a new one on order. I'll put it in a thread guage and find a good brass replacement and solve the problem for good. I used a bigger pair of pliers to turn it in further tonight. We'll see if it holds until next week.
SDR-II
Sep 29, 2015 01:06 AM
cornermike
Jul 30, 2015 06:37 AM
Captjay
Jul 23, 2015 12:33 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
Shifts
Jul 3, 2015 07:59 AM
