1987 Polaris trailboss r/es, NEED HELP!
Old Jul 7, 2006 | 06:55 PM
TheDuck's Avatar
Default 1987 Polaris trailboss r/es, NEED HELP!
I just picked this atv up for $200 bucks, cleaned the carb and drained the tank, runs great...however when I shift from neutral to forward or reverse the gears grind, now following the rear brake cable looks like it somehow maybe doubles as a clutch? When I squeeze the brake cable it idles the engine down so low that it stalls....WTF? It has a little button also on the handlebar, the reverse limiter maybe? This is just a beater quad but I'd like to be able to shift without grinding the gears, thanks for any help!
Old Jul 7, 2006 | 11:19 PM
drlang's Avatar
sounds like the clutch is engaging the belt. Pull the clutch cover and inspect your primary.
Old Jul 8, 2006 | 08:47 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you might have it idled up too high as well. as far as the break making it stall something isnt righjt for sure.
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
binky79
Jul 30, 2015 06:37 PM
Bulgin88
Jul 30, 2015 05:20 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
