01 trail boss 325 reverse not working
Old Jul 9, 2006 | 03:12 AM
gt350tsc's Avatar
Default 01 trail boss 325 reverse not working
my reverse on my 01 trail boss 325 is not working. i can move the gear select lever back to reverse, but the reverse light does not light and it acts like somthing hold it back when push the thorttle. but goes forward realy well.
just wont move reverse any ideas?
Old Jul 9, 2006 | 08:08 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
not sure is there any adjustment on the shifting linkage? if not sounds like something seroius.
Old Jul 9, 2006 | 10:01 AM
ftwflh's Avatar
Check the arm that the shiftrod hooks onto to see if it is loose or stipped out.If it is good you have internal problems.Most likly the snapring that holds the reverse gear to the shaft has come loose.Not a hard fix but takes time to get the tranny out of the frame.
Old Jul 9, 2006 | 08:44 PM
gt350tsc's Avatar
well i checked the shift linkeged and looks fine. i think its the tranny,
shoud i replace the tranny or buy a new atv?
if i buy a new atv i plan running this one until it dies.
i had the rear swing arm repalced recently and chain and both sporkets.
Old Jul 9, 2006 | 11:07 PM
ftwflh's Avatar
I would buy a service manual and repair the tranny.
Old Jul 25, 2006 | 01:17 AM
gt350tsc's Avatar
any repair manuals online?
Old Jul 25, 2006 | 07:46 AM
ftwflh's Avatar
Look on ebay for a factory manual.Or spend the cash at a dealer .I have never found one online.
Old Jul 25, 2006 | 08:15 AM
scootergptx's Avatar
Supersock
Hired Gun!
Luck is a good part of the ebay search. I did find mine on there, and got it for under 25 bucks shipped. If you don't see one, ask the seller of another manual (Trail Blazer for example) if they can get the Trail Boss.
Or, pm me your email, and I can send the tranny section from a 2000 Trail Boss to you.
Old Dec 1, 2019 | 02:00 PM
raywil0654's Avatar
Thumbs up ray
Yes the transmission will have to be removed easy fix after that split the case and you will see a retaining ring clip on the shaft that keeps reverse gear from moving up. just put the clip back in the groove above gear. THIS WILL NOT HAPPEN UNLESS YOU JERK HARD TO PUT IT INTO REVERSE.
MooseHenden
Family ATVing Photos
8
Jun 25, 2015 02:04 PM
wildbill59
Jun 20, 2015 02:26 PM
PolarisPower500
May 17, 2015 02:28 PM
EXtreme
Sep 10, 1999 12:54 PM
Matt24
Aug 3, 1999 07:46 PM
