Question inregard to tire size
Old Jul 11, 2006 | 11:09 PM
ekazmer's Avatar
Default Question inregard to tire size
Hi.
got aquick question what do the numbers 25 x 8 x 12 mean?
Just trying to figure out if a 25x10x11 would replace a 25x11x10 if I change teh wheels has well?
Also is there a Torque requirement for a polaris sportsman 2004.05 HO wheels?
Old Jul 11, 2006 | 11:21 PM
bberck's Avatar
25X10X11 would be 25 high 10 inch wide and a 11 inch wheel
Old Jul 11, 2006 | 11:23 PM
ekazmer's Avatar
That is was i was thinking however Just wanted to confirm
appreciate the hep
Old Jul 11, 2006 | 11:35 PM
thedoc's Avatar
nuther question on tyres
one of my tyres has a slow-to-medium leak
are these tubeless tyres or have they tubes?
or if tubeless and a rim is leaking can you use a tube to stop leak?
Old Jul 11, 2006 | 11:39 PM
okiedude's Avatar
Doc, they are tubeless from the factory. Yes putting a tube in one will seal it up unless the rim has sharp metal causing a puncture
Old Jul 12, 2006 | 12:02 AM
thedoc's Avatar
thanks for that
I think I'll get a tube in it to avoid the need to constantly pump it up
amazing that even at zero psi it virtually has same height as other one at 3 psi [but wanders around a bit]
Old Jul 12, 2006 | 07:31 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
dont know if you can it over there, but theres a product called slime that you put in your tire and it works great for fixing slow leaks.
Old Jul 12, 2006 | 08:57 AM
thedoc's Avatar
I know there is "spare tyre" in a pressure pak so I'll check it out thanks
guess it cant do any harm because if it dont work I need a tube anyway
Old Jul 12, 2006 | 12:57 PM
ekazmer's Avatar
For the Slime do you need to take the tire off or does it go in the air valve?
Old Jul 12, 2006 | 03:04 PM
nitrox's Avatar
It go in the air valve from a pressureized can or you can get it in a squirt bottle. let the air out souirt it in and refill with air.
go to http://www.slime.com/
nitrox
Australia:
Slime South Pacific Pty Ltd
P.O. Box 197 Oaklands Park
SA, 5046, Australia
phone: 08-8270-1011
fax: 08-8270-1044 fax
e-mail:spsales@slime.com
Coolchem
3 Pentland Road
Salisbury,Adelaide,5106
phone: 08.8283.0888
(Hardware, Auto)
Delphi Distributors
77 Boulder Road
Malaga,6090
phone: 08.9249.5333
(Hardware, Auto)
Bratman2
Aug 6, 2022 01:42 AM
toonces
Oct 16, 2019 12:11 PM
Jul 24, 2015 11:57 AM
baysport
Jul 23, 2015 11:37 AM
rcappie4
Jul 18, 2015 07:51 AM
