300ex carb problem
Old Jul 14, 2006 | 05:35 PM
4StrokeRider400's Avatar
Default 300ex carb problem
Alrite, i have a 2001 honda 300ex. The problem is, its leaking out of the overflow pretty bad. After im done riding i will look and half of my swingarm is wet with gas. Ive took the carb off and cleaned it, and just today i put a new needle in, and no luck either. There is either dirt in it or the float is bad, but iu checked the float and it seemed fine, no leaks. So im pretty stumped. But most likely its dirt in it, any help is appreciated.
-Cody
Old Jul 14, 2006 | 05:41 PM
ubertrailblazer01's Avatar
http://forums.atvconnection.com/mess...did/495296.cfm
had the same problem a week ago. bought a new needle, didnt help, i tapped it, tried all different ways to start it, didnt work. use some carb cleaner, it may help. if not, take it into the honda mechanic, they cleaned it out fairly quick. works perfect now.
Old Jul 14, 2006 | 05:44 PM
Joshwfl's Avatar
Check the carbs float setting, it may need adjusting which is very simple. Check the float valve to be sure it's returning to the out position properly. Also check the bottom of your float bowl. There is a tube that runs up toward the carb body from the overflow tube. If it's broken off or cracked it will leak out the tube too.
Old Jul 14, 2006 | 08:27 PM
Thank for the help i will try those things.
-Cody
Old Jul 14, 2006 | 09:01 PM
Floorit's Avatar
I'd say the floads stuck on overflow OR the float bowl seal is not in right.......OR it's torn
fullprice54
Jun 18, 2015 09:44 AM
NONEtooSMART
Jun 17, 2015 08:48 AM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
kevbowe
Jun 1, 2015 01:17 AM
