OT: CR125 Has Weak Spark
Old Jul 18, 2006 | 03:38 PM
RedGoblin's Avatar
Default OT: CR125 Has Weak Spark
I know this is totally off-topic, but I wanted to get the opinions of some of the great minds here. Trying to sell my CR125. It has a very weak spark, but we just put a different, but used stator in it. Is it that this stator is pretty much crapped-out too, or what are the other possibilities?
Old Jul 18, 2006 | 04:22 PM
Joshwfl's Avatar
First, check continuity through the boot. CR's have a way of working loose. If the wire from the coil is stiff, then it's time for a new one. It should be soft and flexible. Unscrew the boot, cut an inch off and put the boot back on. See if the spark gets better. It could also be as simple as a weak ground on the coil. Check that the frame doesn't have any rust or paint where it's grounded. Clean it up, sand down to fresh metal and reattach the ground. Lastly, check the resistance on your coil and your air gap on the pulse generator. Make sure it isn't dirty. My CR500 needs to be set at 0.030 away from the raised portion of the flywheel. Good luck, pm me if you need anything else!
Old Jul 18, 2006 | 06:56 PM
RedGoblin's Avatar
Much appreciated
Old Jul 18, 2006 | 08:58 PM
Joshwfl's Avatar
No problem, that's what places like this are all about. Good luck!
Old Jul 20, 2006 | 11:29 PM
Joshwfl's Avatar
Any news?
Old Jul 21, 2006 | 02:43 PM
RedGoblin's Avatar
Well apparently, the shop got it started, but now we think it has jetting issues[img]i/expressions/face-icon-small-sad.gif[/img]Appreciate the help, though.
fordfaithful21
Dec 7, 2015 05:52 PM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
hueby
1) Engine problems..
Aug 29, 2015 08:34 AM
hueby
Aug 28, 2015 07:26 PM
