sp500 moves when put in gear....
Old Jul 18, 2006 | 06:56 PM
Shortyjd's Avatar
Default sp500 moves when put in gear....
does anybody know why my 500 moves when i put into gear? is the belt worn or would it be clutch problems. thanks
Old Jul 18, 2006 | 07:13 PM
ftwflh's Avatar
Could be either one.Change the belt and if it still creeps have the primary clutch rebuilt.The bushings stick and dont let the clutch release all the way.
Old Jul 18, 2006 | 07:28 PM
sonOFoldmanmoses's Avatar
Well.... Two things...
One. When you put it in gear, it will move somewhat. Not much to really say its "moving". It will move, just like when you put ur car in reverse or something, it will move by itself.
Two. If you took your EBS off, you lost your trusty compression brake, and it will definatly move a small amount, but not much either..
Either way, just look at your belt as ftwftlh says. I dont know about the primary cluth though.. Good luck.
Josh
Old Jul 18, 2006 | 10:22 PM
Sherlock's Avatar
mine did that too after replacing the second belt. it just went away after about 50 hard miles. still does it occasionally but not very often.
Old Jul 18, 2006 | 11:19 PM
MaineMudder3's Avatar
Have had this problem about 5 times in 10,000 miles. Take your primary clutch apart, there is a thin spacer behind your EBS between it and the inner sheeve. The EBS ends up wearing a groove into the spacer causing some play. It is a $.45 part..there is 1 stock from factory but put 2 and you will not have the problem again for a long long time. Problem solved..for sure!
Old Jul 19, 2006 | 12:03 AM
Speeddrive1's Avatar
Would this also cause hard shifting? Like when you go from forward to reverse
Old Jul 19, 2006 | 05:44 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if its idled up too high it might as well. sometimes spray some wd 40 on the linkage at the pivot point and it might help the shifting problem.
Old Jul 19, 2006 | 07:58 PM
ftwflh's Avatar
Yes it would cause both because the front clutch is not releasing all the way.
Old Jul 19, 2006 | 08:40 PM
v2rider's Avatar
Already posted sort of, but is the idle reeal high? If its to high, it might be engaging just from the high rpms
Old Jul 20, 2006 | 01:47 AM
Correct..it would cause hard shifting just like ftwflh said because the primary is still partially engaged.
lonerider856
Oct 13, 2023 03:45 PM
Dewhound
Apr 20, 2017 02:25 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
Elkaholic
Sep 6, 2015 02:44 PM
