02 sportsman 500H.O. too hot to handle.
Old Jul 21, 2006 | 11:18 PM
Gladiator's Avatar
Default 02 sportsman 500H.O. too hot to handle.
My sportsman gets darned hot on the exhuast(right) side in the summer(now). So much so that I can't ride with shorts on! It has a heat sheild that works pathetically, I was wondering if this is normal or do I have a problem . Lotsa oil , antifreeze etc. The machine doesn't over heat it just gets hot on this one side? Maybe my exhaust is partiallly blocked? It seems to flow O.K. Any Ideas?[img]i/expressions/face-icon-small-confused.gif[/img]
Old Jul 21, 2006 | 11:57 PM
Rinman's Avatar
I'm not an expert but I would check your plug for color. If it white your lean. Lean will make that pipe get way hot. You could also try some exhaust wrap. On my drag car I could put my hand on the exhaust after a pass. It was hot but I didn't get burnt.
Old Jul 22, 2006 | 02:05 AM
NemadjiJim's Avatar
Where do you find exhaust wrap? What is the brand name? Sounds like a good idea to have especially since some people have some problems melting plastic on the newer wheelers. Is there any down side of using this wrap?
Old Jul 23, 2006 | 06:56 AM
Gladiator's Avatar
Would having my valves unadjusted effect the heat(some what retarding the timing)? I haven't done this since I bought it in sept 05 and who knows when it was done before that. Is this a difficult process? I usually work on my own vehicles any way.
Old Jul 23, 2006 | 09:02 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
the valve adjustment wouldnt have any thing to do w/ the heat issue. is this a new heat issue, i mean is it worse then it normally is? on my 500 and my 800 they both run hot enough so its not comfortable wearing shorts.
Jmuddin284
Jan 19, 2026 07:16 AM
chingchangchong
Aug 7, 2022 11:36 AM
slowgsxr97
Sep 8, 2015 07:33 PM
Pahuntman
Sep 5, 2015 11:07 AM
cdstang
Aug 31, 2015 07:52 AM
