Honda Gear Lube?
Old Jul 22, 2006 | 02:54 PM
econdave's Avatar
Default Honda Gear Lube?
the front diffrential level, should you be able to see the fluid at the point where you fill it? also the rear diffrential, should you fill until it runs out of the check bolt? Manual says 6.2 oz in front, and 2.5 in rear. They both took a little more than specs. Thank you..
Old Jul 22, 2006 | 03:21 PM
quicksilver's Avatar
it's important for atv to be on level ground to check the fluid level. The front should be up to the bottom edge of the fill hole, the rear should drip out of the check bolt. The manual will give fill spec's and a fill from dry spec's which will be a little more. As long as you have fluid up to the right levels, you're good to go.
Old Jul 22, 2006 | 03:23 PM
econdave's Avatar
thanks for the response. thats what i thought, just wanted to make sure. This forum is awesome. Lots of great info for newbies..
ghost civic
Jan 15, 2020 07:43 AM
greg74
Sep 10, 2019 03:03 PM
CRamshaw777
Jul 18, 2015 05:46 PM
Countrygirl1976
Ask the Editor
Jul 13, 2015 12:19 AM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
