Honda Gear Lube?
the front diffrential level, should you be able to see the fluid at the point where you fill it? also the rear diffrential, should you fill until it runs out of the check bolt? Manual says 6.2 oz in front, and 2.5 in rear. They both took a little more than specs. Thank you..
it's important for atv to be on level ground to check the fluid level. The front should be up to the bottom edge of the fill hole, the rear should drip out of the check bolt. The manual will give fill spec's and a fill from dry spec's which will be a little more. As long as you have fluid up to the right levels, you're good to go.
CRamshaw777
Jul 18, 2015 05:46 PM
