2000 Polaris Scrambler 400 Engine Seize – Piston
Old Jul 23, 2006 | 11:24 PM
scrambler50's Avatar
Default 2000 Polaris Scrambler 400 Engine Seize – Piston
Need some guidance on repairing a scrambler. Purchased 2000 Polaris Scrambler 400 for my son since he outgrew his 50 cc. The quad was just off idle and stalled, locked the engine up. Pulled the cylinder to find the piston skirt opposite the exhaust port broke into pieces. Case and cylinder appear to be undamaged. However, the pieces of piston have stop most of the crank/rod movement. The crank can be rocked slightly. Is there any do’s/don’ts from you pros before I start disassembling the engine removing the piston pieces…
Thanks!
Old Jul 24, 2006 | 10:50 AM
scramblered's Avatar
the stock oem piston is crap,it need to be remplaced with a wiseco,it is now a biased trend to be fixed,
put a top end bearing and polaris gasket back in,and it will last longer than ever if you take care of it at warm up.
Old Jul 24, 2006 | 11:47 AM
conig's Avatar
as long as it didn;t run long after the skirt fell ou may be able to get away with a bottom end flush in diesel fuel. but I did this when my skirt went out and the crank bearings lasted less then 6 months. now about 1.5 years latter I need a new crank becuase my rod bearing finally went.
just something to think about.
rittercycles does great work and has more experience with this engine then any other.
Old Jul 24, 2006 | 12:17 PM
MuddyScrambler400's Avatar
The same thing happened to me but the piece out of the skirt went down into the crankcase and put a hole in my crankcase.
polaris scrambler00
Jun 20, 2015 08:49 AM
hoopduerr
Jun 10, 2015 03:00 PM
wbfjim
Jun 8, 2015 06:20 PM
hoopduerr
Jun 2, 2015 09:01 AM
hoopduerr
Jun 1, 2015 08:22 PM
