LT80 short ciruit
Old Jul 24, 2006 | 10:28 PM
RedEX's Avatar
Default LT80 short ciruit
OK - had a dealer replace the starter on my daughters LT80 a few weeks back. In the few times we've went to start it since then it started developing a hard starting issue again. I initially thought it was the battery and put it on the charger. After just a few minutes on the charger it would fire right up. [img]i/expressions/face-icon-small-confused.gif[/img]
She rode it for about an hour the other night. After we parked it, it started leaking fuel from the carb like crazy. I played with the fuel switch but still kept leaking. Left a nice little puddle on the garage floor overnight. Went to start it again tonight and same probablem again, didn't want to turn over. I happened to look down and noticed a wisp of smoke.... it came from the rubber on the throttle cable melting - about 2 inches above the carb the cable was touching the a bolt coming through the air filter canister. I turned everything off and felt the bolt and it was HOT. It did enough damage to the throttle cable that now it's froze up! [img]i/expressions/face-icon-small-disgusted.gif[/img]
Obviously something is shorting out somewhere. Wondering with the fuel leak if it's leaking down onto the starter and seeping into the connector and that's where it's shorting.
Ideas?
Thanks!
Old Jul 25, 2006 | 11:50 AM
LT80's Avatar
LT80 Expert
I doubt the fuel is the problem.
This is one heck of a dead short. There has to be a bolt wore thru a wire/wires touching somewhere.
I'd start tracing from the battery.
Hmm, just thought, you do have the ground wire on the motor don't you? (right top fan cover bolt)
QuadRiders
Oct 22, 2015 04:13 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
black_thunder
Sep 22, 2015 07:59 PM
merryman
Sep 19, 2015 03:15 AM
Jaymc
Sep 11, 2015 07:45 AM
