Engine alternatives for Warrior?
Old Jul 26, 2006 | 01:11 PM
Mr45auto's Avatar
Default Engine alternatives for Warrior?
Is there a different, more potent powerplant that can be dumped into a Warrior Chassis without a bunch of fabrication? I also want a well balanced engine to keep down the vibration.
My old Warrior needs the engine gone through which although not terribly expensive still wont help it much with power. I figure to make it keep up a little better with the Raptor it will need another engine altogether. Hopefully it's something that can be funded from the sale of a good running Warrior engine.
Old Jul 26, 2006 | 11:49 PM
Mr45auto's Avatar
Old Aug 11, 2006 | 04:16 AM
cruddymutt1's Avatar
I put a 400ex motor in my wifes Warrior. It was cheaper than rebuilding the old motor and it rides killer. Check pics.
Old Aug 11, 2006 | 12:01 PM
Mr45auto's Avatar
How much fabrication was required to make it work? I imagine you had to build your own mounts but were they complex or fairly simple to build up? Was the project laid out beforehand or just eyeball engineered?
Old Aug 11, 2006 | 08:23 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
the 400ex has simple motor mounts... in the same locatino as stock warrior mounts...
Old Aug 13, 2006 | 07:23 AM
The motor mounts were fairly simple. We cut out the stock warrior mounts and braced the motor where we wanted it. We then used cutouts to get the desired motor mounts. We did have to find a place for the oil cooler and oil tank. The stock 400ex oil tank is not usable so we had to make one out of 190 wall aluminum. Remember, no matter what motor you decide to use be it 400ex or a hayabusa 1300, think of all the other stuff you need to mount such as oil cooler, radiators, oil tanks, exhaust routing, etc.
Reactant
Mar 30, 2022 02:08 AM
manuelrivera
Aug 8, 2015 04:34 PM
GNorm
Aug 1, 2015 11:06 AM
Ashley S
Jul 31, 2015 09:46 AM
Reactant
Jul 16, 2015 10:29 PM
