Zerk locations for Magnum
Old Nov 29, 2000 | 09:34 PM
Houndog's Avatar
I went to check out the parts manual for these locations and found out that I'd have to download this Acrobat reader, that I will not need for anything else ever. Thought I'd just ask ya'll to tell me which ones I'm missing.
I found top steering under pod, bottom steering - front of both front struts - side of both front A arms - are the ones for the rear suspension arms under those rubber side caps on each side ? Just pull the caps off ? Where are the others hiding?
Houndog
Old Nov 29, 2000 | 10:36 PM
bowtiepu's Avatar
i beleive your missing 5 fittings on the front.
first 2 are on the front axles on the inside closest to the differential,roll the wheels so the axle turns,youll see a fitting in the middle of the u-joint..other 3 are on frt drive shaft,1st is right where it connects to the frt differential,on that ujoint,the other is on the other end of the same shaft and the 3rd is on the slip collar of the frt driveshaft,closest to the engine..the rear is just 1 i beleive,the rear drive shaft where it connects to the tranny is another u joint..you have to get all 4 wheels off the ground so you can turn the shafts and axles to access them..if i remember right thats should be it
Old Nov 29, 2000 | 10:50 PM
MagnumMudMan's Avatar
Houndog
I would strongly recommend downloading the parts manuals or having someone download and print them for you. They are extremely valuable to have around and are free
Old Nov 30, 2000 | 12:38 PM
Farmr123's Avatar
Bowtiepu got the count & locations right as far as I know. There is no need to jack the machine up, though. Just roll it forward & backwards & the shafts will turn.
Old Nov 30, 2000 | 03:06 PM
kevin_staton's Avatar
From where can you download the parts manuals?
Old Nov 30, 2000 | 04:27 PM
kevin
Go to the polaris website at www.polarisindustries.com and follow the links to atv - trail tips - parts manuals. Hope this helps.
Old Nov 30, 2000 | 05:31 PM
Houndog's Avatar
MagnumMudMan -
You were right. I took your advice and downloaded the stuff and got the parts manual. It is definately a must own, and I thank you kind sir for enlightening and old fart.
technically impaired Houndog
Old Nov 30, 2000 | 05:35 PM
Houndog's Avatar
Hey Farmr123 -
On the single axle suspension, in the rear of course, there are two rubber caps on each side of the swingarm. They are about 3 inches in diameter, and fit rather loosely. The caps have the Polaris snowflake emblem on them. Are there any grease fittings for the rear swingarm, and do these rubber caps cover anything that needs servicing.
Houndog
Old Nov 30, 2000 | 05:40 PM
Houndog
You will find yourself using the parts manuals for all sorts of quad projects. I find myself refering to them just to see how certain pieces are assembled so that I understand what people on this forum are taking about. Print the manual off and keep it as long as you own the quad. Glad I could help.
Old Nov 30, 2000 | 07:25 PM
Farmr123's Avatar
It is my understanding that the rear swingarm pivots on the Magnum models are now permanently lubricated. The caps are there for servicing the 'hinge' or whatever you want to call it. I could be wrong, but I think there is nothing to do behind the covers unless the hinge point starts getting loose or binds.
It is kind of a mixed blessing, being sealed. The zerk behind the rear of the belt cover is a bear to get at, but I still like the idea of being able to put in fresh grease if you go in muck deep enough to get it submerged.
Don't forget to check hub oil level every now and again. Takes only 5 minutes and can be a lifesaver. If a leak develops, the oil will likely be gone before you notice the spot on the garage floor.
EIF
Apr 20, 2017 07:15 PM
Gwolf228
Feb 18, 2017 01:36 AM
Oct 10, 2015 10:20 AM
Lucas Bohanan
Sep 29, 2015 01:16 AM
bigred20653
Sep 19, 2015 02:11 PM
