carb question rappy
Old Aug 3, 2006 | 03:35 PM
michaelsangaree's Avatar
Default carb question rappy
i have a 04 raptor 660 and the carbs are draining gas out of the drain hole while the engine is idling as soon as u give it gas it is fine
5th gear boggs a little also is the carb fauling causeing it
it is the carb on the right side the left siode did it at first but stopped
Old Aug 3, 2006 | 03:40 PM
2001Bansheeboy's Avatar
sounds like you are running it too rich. Try leaning out with the mixture screw, but if that isn't enough you'll need to get a smaller jet
Old Aug 3, 2006 | 03:54 PM
little more info i took the gas tank off checking the valves long story but anyways did not rejet the carbs working fine before i took the tank off soon as i put the tank back on it was a river of gas going through the carbs
Old Aug 3, 2006 | 05:15 PM
JLsparky7's Avatar
Check ur float, doesnt sound like a jetting prob.
Old Aug 3, 2006 | 05:22 PM
Baseballroxmasox's Avatar
Try taking the carb apart and cleaning it up a little bit... like sparky said, it does sound like your float is getting stuck. Cleaning to carb should fix you right up!
Z
Old Aug 3, 2006 | 05:52 PM
Yeah, if that's all you've done, then the float is stuck, I'm suprised it started though. Also check to make sure it isn't upsidedown or bent, I've seen both cause similar effects
Jmuddin284
Jan 19, 2026 07:16 AM
200es
Jul 10, 2015 09:09 AM
tweeder
Jul 5, 2015 01:57 PM
yambam13
Jul 4, 2015 01:49 PM
Mikea1978
Jul 4, 2015 12:37 PM
