90 viper wont start
Old Aug 6, 2006 | 11:07 PM
marlbroman400's Avatar
Default 90 viper wont start
have spark fuel and air but wont start.whats next.
Old Aug 7, 2006 | 12:56 AM
sejust2005's Avatar
What year of quad is it? Do you have any compression? Did you check for water in the gas? I would first take off the carb and inspect for debris or water. You can usually spot water in the float bowl, since it does not mix with gas... it will be small bubbles at the bottom. If nothing but gas is in the bowl, clean the jets with carb cleaner and see if any debris is lodged there. If this is all normal, you might want to check the compression. If you do not have a compression gauge, you can get an idea if you just put a finger over the sparkplug hole and crank it. It should blow your finger off with a good amount of force. While you have the spark plug out, check it for fouling also.
Old Aug 7, 2006 | 01:02 AM
already cleaned carb piece by piece.gas is clean.seems to have good compression with finger test.its an 04.tried a little starting fluid also.nothing.
Old Aug 7, 2006 | 10:23 AM
LT80's Avatar
LT80 Expert
Try removing the filter or whatever is on the end of your carb. Place your hand/fingers in front of the carb to hand choke it and try to start. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Aug 7, 2006 | 07:55 PM
superbombman's Avatar
I've said it before and i'll say it again try the ign. switch!!!!!!
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
garyt1975
Jun 5, 2015 08:53 AM
Fnqrider
May 31, 2015 08:29 AM
1000gade
May 27, 2015 12:37 PM
