gearing 06 450er
Old Aug 7, 2006 | 06:52 PM
chenoweth122's Avatar
Default gearing 06 450er
i want to gear down my 450. i was told that switching the front sprocket to a 13 tooth would do the trick, any other suggestions for gearing down.
Old Aug 7, 2006 | 09:47 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
The 06 is geared down from the 04/05, and personally I think the 06 is right on. I would think that gearing down would be to much. It would be so troquey that you would have trouble keeping the front end on the ground. Try maybe a tooth bigger in the back or something. (They say 1 tooth in front = 3 teeth in back.)
Old Aug 7, 2006 | 10:49 PM
35Charlie's Avatar
I thought '06 came with a 13T stock like the CRF? That leaves the back one as your better option. 12T is awful small and harder on the chain.
Old Aug 7, 2006 | 11:22 PM
for some reason i thought that the front sprocket was a 15 tooth on the front. maybe i am wrong i will have to check that. and i did not know the 1 tooth= 3 teeth on the back. thanks a lot. one of the reasons that i want to go lower gear is it is having a hard time in 5th. it takes about 2 seconds for the power to kick in 5th gear, i have got the jetting right i believe. the machine is only 2 months old.
Old Aug 8, 2006 | 02:58 AM
zettler450r's Avatar
the 06 comes with 13 and 04 05 comes with 14.... Why would you want to go down a tooth, I just put a 15 tooth on my 05 and it rips up the trails, it seems soo much faster... Going to 12 would be crazy... Just my .02$...
Old Aug 8, 2006 | 11:53 PM
let me make sure that i get this. by adding teeth to the front it gears it down or up, same with the rear, adding gives you lower gears ( more torqe, less top end ) and lowering teeth is more top end?
Old Aug 8, 2006 | 11:57 PM
bberck's Avatar
smaller front sprocket = more low end/less top end
larger front sprocket = less low end/more top end
smaller back sprocket =less low end/more top end
larger back sprocket = more low end/less top end
CHART
Old Aug 9, 2006 | 02:11 AM
first off, nice quad. i bought my first new quad and first quad period. thanks for the info, i am trying to make this thing fast. once agian i appreciate it.
lonerider856
Oct 13, 2023 03:45 PM
Honski250r
Sep 26, 2015 09:40 PM
patrick.oc123
Sep 15, 2015 02:45 PM
bigbear350quad
Sep 11, 2015 12:40 PM
awer1968
Sep 8, 2015 11:02 AM
