05 Grizzly problem, help
Old Aug 9, 2006 | 03:50 PM
Pinkster660R's Avatar
Default 05 Grizzly problem, help
my father has a 05 grizzly camo edition. well, as of this week the throttle has started hanging open. We took the gas tank off and looked at the cable and it looked fine. after we took the tank off the throttle loosten back up and worked fine. Two days ago, dad took it out again, and it hung wide open again.. I fooled with the cable and finally got it unhung, but it looks like the trouble is in the box beside the pipe. Im thinking maybe the heat is gettin to it or something. does anyone know a solution to the problem???? Is the tank pushin up and kinking the cable? could this happen
Old Aug 9, 2006 | 03:58 PM
2TV's Avatar
2TV
Inside that box beside the pipe (the cable end opposite the throttle) make sure there is no mud / grit in there. That happened to my '02 once early on. The problem was a cracked cable casing at the edge where the metal cap ends, that was letting material get in there. A little bit of dust, mud and / or water built up over time to the point where the throttle would stick. In my case it was fixed under warranty back in late '01. It wasn't the cable that was sticking, it was the linkage that the cable connects to...
RedRancher
Oct 15, 2020 01:45 PM
greg74
Sep 10, 2019 03:03 PM
hondarider1234
Jul 21, 2015 11:53 PM
MATT BOOTH
Technical and How-To Articles
Jul 20, 2015 07:38 PM
MATT BOOTH
Utility ATVs
Jul 20, 2015 05:55 PM
