04' Honda Rincon Rearend Noise
Old Aug 15, 2006 | 11:47 PM
SherpaT350's Avatar
Default 04' Honda Rincon Rearend Noise
I m having the rearend on teh rincon make weird noises , especially when backing up . I think it might be the disk brake on the rearend driveshaft . There seems to be slop there when moved back and forth by hand . Is this assembly suppose to be rubber mounted ?
Or what might be the problem ?
Thanks,
D.
Old Aug 16, 2006 | 09:37 PM
ForemanDan's Avatar
There was a guy on RinconRiders.com that said something about chatter on the rear disc. Apparently the rivets had a little play in them. I think he put a piece of metal on one side and tapped the other with a hammer to tighten the rivets.
Old Aug 17, 2006 | 09:34 PM
RancherATCrazy's Avatar
You say slop when you move it back and fourth by hand, is your disk straight???
Old Aug 17, 2006 | 11:31 PM
SherpaT350's Avatar
yes, when I reach under between the rear fenders and grab ahold of the rear disk, I can move it radially without the drive shaft moving . Is this disk just held onto the rear driveshaft joint by rivets ? It looks like to me, that some kind of rivets are worn and allowing this movement. Has anyone else had this happen and cause noise that can audibly be heard ?
I just don't know how this is mounted to the drive shaft.
Does anyone have a page out of the service manual that shows the parts and how it is mounted ?
If so, I do have windows messenger if they would be so kind as to send me the file.
Thanks so Much,
D.
Nondem
Feb 22, 2020 12:20 PM
greg74
Sep 10, 2019 03:03 PM
Divergent12
Dec 30, 2017 08:33 PM
Bonzhonda300ex
Sep 17, 2015 10:44 AM
hondarider1234
Jul 21, 2015 11:53 PM
