Warrior metal shavings..
Old Aug 19, 2006 | 07:46 PM
CanadianGM's Avatar
Default Warrior metal shavings..
So i sold my warrior yesterday and the guy phones back today pissed off that he found metal shavings in the oil and oil filter. THe motor was rebuilt in jan 04. IS this normal to have metal shavings sitll in the oil? If he changed the oil filter and the oild do you think metal shavings will still come up?
Old Aug 19, 2006 | 07:50 PM
bberck's Avatar
Yes it is normal to have small amounts of metal in it. Now if it has alot that could be a problem.
counterpunch's Avatar
How many hours did you have on the rebuild and was the oil ever changed in between the time of the rebuild and when you sold it?
Old Aug 19, 2006 | 07:53 PM
CanadianGM's Avatar
Yes i changed it once and there were shavings. I cleaned out the filter but didn't replace it.
THe quad has probably 50 hours on it tops.
Old Aug 19, 2006 | 10:03 PM
JLsparky7's Avatar
Theres your prob, you should only reuse a reusable filter. Never just clean it out... replace it... its like 4-5 bucks... not worth having to get a new trans over.
Old Aug 19, 2006 | 10:06 PM
CanadianGM's Avatar
so if he replaces the oil and oil filter, you can't really see a problem from now on? I had it for 2 years and never had a problem.
Old Aug 19, 2006 | 10:42 PM
JLsparky7's Avatar
Put good quality oil and good oil filter and change both 3-4 times a year and a garuntee he will not have a prob.
Its probably just the clutch plates wearing down, its a part of wear and tear. You didnt run car oil in it did you?
Old Aug 19, 2006 | 10:46 PM
CanadianGM's Avatar
nope it was the correct oil. i jsut didn't change it enough, but i rarely rode it as well.
Old Aug 20, 2006 | 01:38 AM
Speedy2222's Avatar
Is A Power Sport Junkie!
it may also be from him improperly using the reverse
Whitelx1
Oct 2, 2015 10:55 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
nastyblaster100
Sep 13, 2015 01:19 PM
