How fast is a stock Rubicon
Old Aug 21, 2006 | 01:52 PM
rubicondude's Avatar
Default How fast is a stock Rubicon
Can someone tell me how fast a 2007 stock Rubicon 500 should go. I have a new one, and it only goes 50 mph. I was told that it would go 60 mph. Can someone tell me what the top speed is really.
Old Aug 21, 2006 | 02:25 PM
RSeb's Avatar
I have an '05 and it tops out around 56 on the speedo. According to the GPS, it is more like about 54. Honda increased the size of the carb in '06, so I would think it would be slightly faster.
Of course a lot of things is going to effect top speed including altitude, temp, weight, etc.
But really - how fast do you want to go on a 600lb quad?
Old Aug 21, 2006 | 03:05 PM
500rubicon's Avatar
With the option of 2wd and increased carb the 06,and 07 should be able to do 60mph.If you engine isn`t broken in yet you might not be able to get as high of a top speed until the engine is broken in.I have had my 04 doing 60 and with the changes over the past few years an 07 should be able to do it also.
There is a way to get alittle more out of the older rubicons not sure if its the same on the 07.The older models had some throtle slop which was said to make the carb stay slightly closed instead of fully open, just ajust the throtle cable and then you should be able o get alittle more top end.
Old Aug 25, 2006 | 03:06 AM
Specta's Avatar
The fastest our's has gone is 55, for the first year it wouldn't go over 53.
Unless the newer ones turn more RPMs I don't know why they would go any faster.
Are the 2007s out all ready?? Any changes?
Old Aug 25, 2006 | 09:16 AM
PETE16's Avatar
I've had my stock 05 CTE up to 98kmh on pavement (according to the speedo). When you convert that to Mph it is 60.89mph. With my 26" mudlites the speedo will not read that fast though.....even though I am probably still travelling that speed.
I am dumbfounded if you can only get 50mph out of yours????
In Canada, Honda came out with the CTE in 2005 which has the bigger carb and a remapped tranny. The tranny improvement seems to make a big difference!
Old Aug 25, 2006 | 11:18 AM
garyc660R's Avatar
I witnessed a completely stock Yamaha Blaster cruise right by an 06 Rubicon that was topped out. If you need speed buy a sport quad.
Old Aug 25, 2006 | 11:49 AM
PETE16's Avatar
I agree....utes are not built for speed.
Old Aug 25, 2006 | 01:55 PM
Specta's Avatar
I forgot about the re-mapping, I am sure that would help.
I saw a totally stock Rancher 350 4X4 blow right past a 660 Raptor in 12" of snow.
Pehter
Oct 3, 2024 11:00 PM
ReconBayou
Oct 31, 2022 05:37 PM
dannytas
Sep 26, 2017 06:31 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
