fan override on the 06 rincon
Old Aug 22, 2006 | 10:57 AM
sbripple's Avatar
Default fan override on the 06 rincon
has anyone done a fan override on an 06 rincon? Its diferent from previous years and the plans on mudanddirt.com dont work.
Old Aug 22, 2006 | 09:31 PM
ForemanDan's Avatar
I did it. I did not follow the instruction on location but I think the hookup was the same. I connected in at the plug mounted on the left side of the frame behind the front shock. There are two wires. One Pink/Blue and one Green/Black. Connect one side of your switch to the Green/Black and the other side to ground.
Old Aug 22, 2006 | 11:10 PM
sbripple's Avatar
thanks a lot .Will have to take all the plastic off again to get at it.
Old Aug 22, 2006 | 11:13 PM
sbripple's Avatar
Is it under the shifter lever?there are two connectors there.one 3 wire one 2 wire.
Old Aug 23, 2006 | 10:14 PM
ForemanDan's Avatar
Just pull off the left front wheel. I may have also removed the inner fender or loosened it.
Old Aug 27, 2006 | 09:18 AM
sbripple's Avatar
thanks a lot dan ,it worked great.
Nondem
Feb 22, 2020 12:20 PM
neilbedwell
Nov 10, 2018 11:02 AM
YZGUY
Sep 21, 2001 10:12 AM
lyle1
Mar 3, 2001 12:44 PM
