Alternate starting methods, Newb ?
Old Aug 23, 2006 | 05:48 PM
Murfx's Avatar
Default Alternate starting methods, Newb ?
The 2001 LT160 only has an electric start - no pull start.
If the starter fails, is it possible to put it in Neutral, get it rolling, and pop it in 1st gear to start it?
(Push Start)
Thanks
Old Aug 23, 2006 | 07:13 PM
400fnSport's Avatar
Don't know much on the 160, but if it is a manual clutch, then yes, but you may have to put it in like 2nd or 3rd depending on the gearing. Most won't start in first due to the gearing, and will just slide the tires. If it's a centrifugal clutch, you can't. That would be one without a clutch leaver.
Old Aug 23, 2006 | 07:18 PM
400fnSport's Avatar
I just looked up the specs and I think its an automatic clutch, so probably not.
Old Aug 23, 2006 | 07:58 PM
Scooter86's Avatar
Knows Old ATV Questions!
You can pull start an auto clutch, but you have to pull it behind a car or another atv, etc. It takes longer to start that way than a full manual, and is probably pretty hard on your atv.
Old Aug 23, 2006 | 08:48 PM
ajd187's Avatar
Interesting...so I assume the same would be true with a Rekluse as well?
Old Aug 23, 2006 | 09:50 PM
Murfx's Avatar
Yes, sorry, I forgot to mention it is an Auto-clutch.
That was the reason for my question - I've start vehicles in the past that way by popping the manual clutch after they are rolling and wondered how that works (or not) with an Auto-clutch.
So basically hope you don't get stranded when the starter quits huh?
Thanks,
Old Aug 23, 2006 | 11:19 PM
Scooter86's Avatar
Yeah, pretty much. I have done it before but it seems like an awful lot of abuse to the machine. I don't think it would work well just by pushing either. Allen, I don't know about the Rekluse, never used one. You could always try it out by getting her rolling, hitting the kill switch, and then turning it back on to see if she will fire back up though.
Old Aug 24, 2006 | 01:17 AM
ajd187's Avatar
I will try that since I'm curious. I think it will work since I can engage/disengage the clutch with the lever like normal.
MikeyBoyesq
Nov 27, 2020 02:44 PM
EZRyde
EZ Ryde Exhaust
Jul 30, 2015 12:46 PM
1000gade
May 27, 2015 12:37 PM
momofo
May 27, 2015 12:06 PM
minehunter
Jan 11, 2001 08:53 AM
