Blaster won't idle
There is a screw on the side of the carb its basicly thew idle adjustment screw turn it all the way in then back it out 1 1/2 turns if your blaster is stock. If not then you can just fiddle with it and figure out what works best.
Does your blaster still have the tors system on the carb. It may be causing the problem if it runs but won't idle. I would remove it. You have to buy a kit that has a new cap and throttle cable. You also have to splice the wires inside the thumb throttle. Here is a discussion about it. TORS removal The screw on the side off the carb is the air screw, the idle adjustment is the knurled **** on top off the TORs on top off the carb. That is if you have a stock carb with the TORS
