Rancher and 450 Rims?
Old Dec 3, 2000 | 09:57 AM
MaoZ's Avatar
Do the 450 rims match the Rancher rims? I mean do they have the same pattern? I want 12" rims for the back of my Rancher but I want them to match the front rims. Where could I get back stock 450 rims? Anyone selling any on here? Should I just get aftermarket rims? What kind of price should I expect to pay for stock rear 450 rims? Thanks for the information!
4x4 Rancher, GPS, 1500 Winch
Old Dec 3, 2000 | 10:53 AM
snowshark's Avatar
They should fit. Most of HOnda utility quads have the same 4/110 pattern. Thats 4 lugs with 110 mm distance between the lugs.
Old Dec 3, 2000 | 11:05 AM
Buckfever's Avatar
I have a set of 450 rims on my Rancher with 25" by 8" and 10" by 12" Dirt Devils. The rims work fine. The tire choice was the need for a lot of rock riding and all around use. I have noticed that the 12 " rim in the back alog with the 6 ply tire tighten up the ride. It is not as cushy as before. However 100 miles of backcountry extreme hunting at less than 5 miles an hour, no flats, only used the winch twice and that was steep slippery rocks. The Honda rims are pretty light weight compared to other steel rims but they are strong this I can attest too.
Hope this helps.....
Old Dec 5, 2000 | 12:01 AM
rancher's Avatar
i have run 450 rims and tires on my 4x2 rancher for over a year now and they work fine. if you use them on a 4x4 you have to get differant size tires for the front as the gearing will be messed up with the standard 450 tires. they give you about another inch of clearance and i think as they are taller a little better ride. hope this helps.
rancher
Johnny Mac
Aug 15, 2019 03:13 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
Clint Russell
Sep 25, 2015 03:20 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
rgjackson
Sep 17, 2015 11:21 AM
