honda atv problem
Old Sep 2, 2006 | 02:42 PM
moosehunter2's Avatar
Default honda atv problem
the problem is that when Im driving it in any gear at any temp. it will die.
When I put in neutral it will start right away and run perfect but if i put it in gear (1st /reverse) it will die but restart when in neutral this will happen 2 to 15 times then the probelm will go away for maybe 1 hour to 2 days it is totaly intermitent I have checked the neutral switch and reverse switch but they check out ok have you seen this problem before can you help
Old Sep 2, 2006 | 02:48 PM
raintheroman's Avatar
I've had this problem with a new 2006 trx250. Not all the time.
Has anyone ever had a rock get stuck in the shift cables causing the quad to go right into reverse?
Old Sep 3, 2006 | 10:15 AM
xtc's Avatar
xtc
My wifes recon did the same thing,try adjusting Idle screw on carb. to idle slightly higher.Found the it would idle great in neutral but under load(especially when hot) it would stall every 10 minutes or so.
Old Sep 3, 2006 | 10:22 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
What model and what year???? Hard to be much help without knowing that......
Old Sep 3, 2006 | 11:19 AM
I forgot to mention the year /model it a 1986 honda 350 trx 4+4 and its like the spark shuts off when put in gear
Old Sep 4, 2006 | 12:06 AM
Midnightspecial2005's Avatar
I have a 2002 Honda 400 Foreman FW and i had trouble with the shocks bottoming out so i put progresive shocks on it and it still does the same thing any suggestions
Sjrpp
May 2, 2023 03:59 PM
hugemoth
Jul 20, 2020 03:28 AM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
