300EX Top End Rebuild
Old Sep 4, 2006 | 09:04 PM
bigjohnjeeper's Avatar
Default 300EX Top End Rebuild
Hi, I'm rebuilding the top end of my son's quad and forgot to get a manual for the torque specs, etc. I want to get it put together quick as possible and not wait on a manual to ship. Is there a place to get this info online or could someone post it from their manual? I'd sure appreciate it. Main things are head bolt and valve cover torque specs, valve rocker clearance, and any other tips you might think of. Thanks for any help!
Old Sep 4, 2006 | 11:22 PM
hondabuster's Avatar
the cylinder head bolts and flange nuts (10 mm thread) are 29 ft/lbs, and they both need engine oiling on the threads and mateing surfaces.
the 6mm threaded fasteners are 7 to 9 ft /lbs
valve clearance is .004" plus or minus .001"
Old Sep 5, 2006 | 11:28 AM
Thanks hondabuster, That's what I needed! I will oil those threads. I expected the head bolt torque spec would be higher. They sure "snapped" when I broke them loose. Must have been from 10 years of time. Thanks again.
Old Apr 11, 2017 | 04:24 PM
Honda rider1989's Avatar
Default Honda quad
Anyone know what the valves are suppose to be set at I have a honda 300 ex need the gas and exhaust set and any ideas how to find the bolts for the cylinder head
Old Apr 12, 2017 | 07:41 AM
Ajax's Avatar
Do a google search on "Honda 300ex" service manual. 1st link i found a free service manual.
As for parts look at hondapartshouse.com..
Good luck
Beeline08
Nov 11, 2016 04:00 PM
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
CosmoM
Sep 21, 2015 04:57 PM
