how do I correctly remove the tors on blaster?
Old Sep 5, 2006 | 10:12 AM
glock22's Avatar
Default how do I correctly remove the tors on blaster?
I just bought a new 28mm d slide carb for my wife's blaster and need to run without the tors system. I removed the whole assembly on top of the old carb including the small switch, but the thing doesn't want to start let alone idle when I do get it to start. What do I need to do, if anything, with the small switch inside the thumb throttle assembly? also all I did with the wires that went to the old switch on top of the carb was disconnect the plug and leave it. Do I need to jumper these out or something? Thanks.
Old Sep 5, 2006 | 01:23 PM
glock22's Avatar
Noone here has removed this system? Surely it can't be all that uncommon to ditch this crap?
Old Sep 5, 2006 | 07:35 PM
mdebuck's Avatar
what is a tors system???
Old Sep 5, 2006 | 07:46 PM
glock22's Avatar
Maybe I have mispelled it but that darned close. This is the system with a switch at the throttle assembly and a switch on the top of the carb which has something to do with controlling the idle. My new carb does that the old fashioned way and I need to remove the entire old system beforee the quad will idle at all or run properly.
Old Sep 5, 2006 | 09:13 PM
Boomer2's Avatar
At the thumb throttle assembly take the switch out and splice the wires. The wires that go to the carb just need to be diconnected. Here is some pictures of what to do TORS Removal
Old Sep 6, 2006 | 12:16 AM
JLsparky7's Avatar
Disconnect the wires that are attached to the box under the front left fender attached to the frame.
Cut the wires on the bottom of the silver part on the peice of top of the carb.
Cut the wires going to your throttle box on your handlebars
Trace all these wires and there should be plugs (under the tank) were you can unplug and completely detach them.
Reset your idle and you might have to mess with your air mixture screw, then your all set. that post above is a great link as well.
Old Sep 7, 2006 | 08:09 AM
glock22's Avatar
I don't see a box under the left fender, but under the front cover there are three. Are you referring to the plastic box with the three pin connector that has a yellow, black, and a black with white tracer? These are at least very similar to the ones going to the switches for the tors system but none have continuity with the wires going to the switches. I have tried disconnecting all this stuff and still cannot get this thing to start, not even to sputter. All I did was change the carb, but now I don't seem to have any spark.
Old Sep 7, 2006 | 02:18 PM
JLsparky7's Avatar
It should be inside the left front fender attached to the frame. There is 1 philips screw holding it on. Its a 1inch by 2 inch black box. Not sure on the color wires. The previous owner might have taken it out already. Your idle might not be high enough on the quad eighter since you changed the carb. Try turning that up. Take a look at your reeds too. Is it getting a spark?
Old Sep 7, 2006 | 08:52 PM
Boomer2's Avatar
Did you splice the wires that go to the the thumb throttle assembly?Whether you remove the box or not shouldn't have any effect since you've disconnected it.
Old May 24, 2019 | 11:10 AM
Kyle Janulis's Avatar
If you are not looking to buy the kit to replace it follow this video here to bypass the TORS
slowgsxr97
Sep 8, 2015 04:37 AM
scott1988
Aug 18, 2015 08:44 AM
Cantbuytime
Aug 16, 2015 09:13 PM
315blaster
Aug 8, 2015 08:13 PM
drewy2dope
Ask the Editor
11
Jul 31, 2015 09:36 AM
