Grizz problem
Old Sep 5, 2006 | 09:40 PM
cra660's Avatar
Default Grizz problem
sometimes my grizz "seizes" but its not the engine.I think its something in the trany/clutch.It usally happens when i haul it somewhere,it would take awile to break it free but now its doing it whenever it wants to.Has this ever happened to anyone?
Old Sep 6, 2006 | 12:15 AM
JDQuadRider's Avatar
Does it seize when you're driving it or does it just die at idle and you're unable to turn it over to start it?
Old Sep 6, 2006 | 01:50 AM
cra660's Avatar
No it drives and idles fine.It just has trouble starting sometimes,I think it depends on how i shut it off.Ive been making a point of trying to put it in nuetral before i shut it off to see if it makes a difference,but i think its something more complicated.
Old Sep 6, 2006 | 09:27 PM
Mine had trouble starting the other day. It turned over fine but wouldn't fire for nothing. I checked to see if it was getting spark and it was. I made sure I had the fuel turned on and it was which led me to believe that either a float was sticking or the choke was sticking. It was most likely the choke since it died when i tried adjusting it. I tapped on the carburetor a bit and it freed itself up. It started fine after that.
Old Sep 6, 2006 | 09:45 PM
cluby's Avatar
Never heard of this yet, but let see what we can figure out, next your go to start it, take a volt meter on put on battery should have around 12.5 volts, try and start it and see what it read if it drops past 10 volts battery is junk.
Have you pull the clutch cover off of it, maybe something fell down one of the snokles. When it does turn over do it make any unusaul sounds, yamaha is know for starter clutchs going bad.
Old Sep 7, 2006 | 02:13 AM
cra660's Avatar
Its not the carberator,iv had my floats stick before.when that happened it would still turn over.When mine "seizes" it wont even turn over.It ties to once then makes some sort of compression noise,then i put it in gear and try to roll it around a bit and eventually somthing breaks free and it starts firing again.Im gonna ckeck my clutch and recoil starter,Thanks for your suggestions ill let you know if i figure it out
Old Sep 21, 2006 | 05:59 PM
GRIZZLYMAN69's Avatar
grizz problem:If the tranny light is not on in park or neutral mine will not start. Just rock machine back and forth until the light comes on and it will start.
Old Sep 22, 2006 | 12:28 PM
downeaster's Avatar
Sounds to me like a bad cell in the battery. Try another battery.
toonces
Oct 19, 2015 02:21 AM
toonces
Jul 23, 2015 02:21 PM
toonces
Jul 16, 2015 03:19 PM
toonces
Jul 15, 2015 07:14 AM
toonces
Jul 11, 2015 12:01 PM
