Can't get it started!
Old Sep 8, 2006 | 08:52 AM
300exBirddog's Avatar
Default Can't get it started!
Old Sep 8, 2006 | 08:55 AM
Any ideas on what is wrong w/this quad.
Sundiro Ridgerunner 50cc, 2 cycle.
Has spark, getting fuel to the motor, has 65psi for compression.
I have even shot fuel into the cylinder and carb just to see if it would pop.
It does nothing but turn over.
Any ideas out there?
Old Sep 8, 2006 | 10:20 AM
sheepdogMSP8117's Avatar
Try starting fluid and a new spark plug. Make sure the air filter isn't clogged. And make sure the exhaust isn't plugged, if there's a spark arrestor, it might need to be cleaned.
Good luck.
Old Sep 8, 2006 | 10:21 AM
Scooter86's Avatar
Knows Old ATV Questions!
Isn't 65psi a bit low for compression?
Old Sep 8, 2006 | 10:47 AM
I was not sure if the compression is low for this quad.
I have tried the starting fluid into the cylinder and carb w/out airfilter installed.
Old Sep 8, 2006 | 12:01 PM
Raptorlegs's Avatar
T Rex Rider
What irritates me is!
Those 6-packs work pretty good.
65psi is too low. You held the throttle open while testing?
Old Sep 8, 2006 | 12:14 PM
I do not think that I had the thottle open when checking the preasure. Does it make a difference?
Old Sep 8, 2006 | 12:30 PM
Raptorlegs's Avatar
T Rex Rider
You're reading will be low if you don't.
Old Sep 8, 2006 | 12:39 PM
I will test it again then. What should I be getting for PSI? I am not familiar w/2 cycle motors and their corks.
Old Sep 8, 2006 | 01:53 PM
Raptorlegs's Avatar
T Rex Rider
Over 100, I would think.
