warrior dies
Old Sep 9, 2006 | 12:58 AM
olwarrior's Avatar
Default warrior dies
Ok its old and tired but i just need it to run ok for now till i have the money to buy a new quad, since i dont think an 88 is worth a full rebuild and big bore. ANYWAY it starts right up, idles fairly smooth and in netural has quick throttle response, however after rapping it through some gears if i let off the throttle (clutch in or out) it will die unless i rev it up. once it stops and am sitting there it runs fine. help please!!
Old Sep 9, 2006 | 01:05 AM
JLsparky7's Avatar
Clean airfilter?
Fresh quality oil?
New plugs?
Fresh gas?
Clean the carbs? (prolly your problem)
Have you tried all of these?
If it were a compression/rebuild problem it would be acting weird all the time. Not just when you let off the throttle.
Old Sep 9, 2006 | 01:16 AM
olwarrior's Avatar
has new plug (ngk d8ea) new oil (yamalube) fresh gas with additive, cleaned air filter(does it with or with out air filter) sprayed carb cleaner in carb but thinking i should problly take carb off and apart and clean throughly. Whats a new carb cost. the guy i got it from said it was rebuilt 3 years ago. I know this motor has sucked sand, as it still had the factory air filter setup all these years.
Old Sep 9, 2006 | 01:09 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
is the idle high enough?
ultangler
Nov 30, 2024 01:35 AM
Pehter
Oct 3, 2024 11:00 PM
2many2ride
Sep 27, 2015 04:35 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
