Warrior Engine mount bolt torque... NEED ASAP PLEASE!!!
Old Sep 10, 2006 | 04:41 PM
DirtDog15's Avatar
Default Warrior Engine mount bolt tourqe... NEED ASAP PLEASE!!!
I need to know what the torque spec is for the rear lower engine mount bolt on a 2002 Warrior.
Thanks.
Old Sep 12, 2006 | 03:37 PM
DirtDog15's Avatar
Default Warrior Engine mount bolt torque... NEED ASAP PLEASE!!!
Ok... I guess out of all the warrior owners on here no one has a repair manual???[img]i/expressions/face-icon-small-shocked.gif[/img]
I figured it out though... I have the haynes banshee/Warrior repair manual and it has all the torque specs... except the engine mount bolts for the warrior.[img]i/expressions/face-icon-small-disgusted.gif[/img] I read the steps in the book about removing and installing the engine, and it just says to tighten the bolts securely. I torqued the bolt to 18 ft/lbs. BTW, I did not have my engine out, I was cleaning her up and noticed that the lower rear mount was loose, the rest of them were tight though. I hope this helps someone out in the future.
Jack[img]i/expressions/face-icon-small-smile.gif[/img]
Old Sep 12, 2006 | 06:32 PM
warriorman16's Avatar
HEY!! i have a warrior repair manual for a 1994. It is down in the building with my fourwheeler. I could look it up for you and get back to ya.
Old Sep 12, 2006 | 07:15 PM
Evasiveone's Avatar
53 ft/lbs for the lower mounts and 24 ft/lbs for the upper mount
Old Sep 13, 2006 | 12:58 PM
DirtDog15's Avatar
WOW... Thanks guys.[img]i/expressions/face-icon-small-wink.gif[/img]
53 ft/lbs??? are you sure Evasiveone??? that seems high... I could be wrong though.
One more thing, how do you torque a mount bolt??? I just put a box end wrench on the nut and let it rest against the frame and torque the bolt, Is this right???
Thanks
Jack.
Old Sep 13, 2006 | 05:09 PM
DirtDog15's Avatar
I called the local yamaha shop and they said the lower mount bolts go to 43 ft/lbs and the upper ones go to 38 ft/lbs
[img]i/expressions/face-icon-small-confused.gif[/img]
Maybe the bolts have different torque specs from year to year...[img]i/expressions/face-icon-small-confused.gif[/img]
Jack
Reactant
Mar 30, 2022 02:08 AM
Countrygirl1976
Jul 13, 2015 10:08 AM
cornermike
Jul 8, 2015 11:44 PM
Shifts
Jul 3, 2015 07:59 AM
bikedad3
Jul 2, 2015 02:15 AM
