Grinding going into High
Old Sep 11, 2006 | 06:13 PM
Cormacs's Avatar
Default Grinding going into High
Hi, I'm very new to polaris quads and am curious if it is normal to do a little gear grinding noise when going into high. I have a 500 EFI sportsman with EBS and every other time I put it into high it grinds for a short time (about 2 seconds) then finally goes into gear. Is this normal. Another thing is 1200 RPM the normal idle? Thanks for any help you might be able to lend.
Old Sep 11, 2006 | 06:45 PM
xler8ion's Avatar
1200 rpm is normal--grinding is not-sounds like your gear selector linkage is not adjusted correctly if it is then probably a trans prob
Old Sep 11, 2006 | 06:54 PM
2manytoys's Avatar
Or you may be puting it into gear too slow. It will gring if too slow.
Old Sep 11, 2006 | 06:55 PM
Cormacs's Avatar
Actually I find it worse when slamming it into gear. It is going into the shop on thursday to have some wheel studs replaced so I'm going to mention it.
Old Sep 11, 2006 | 07:55 PM
sheepdogMSP8117's Avatar
You shouldn't have to slam it into gear, but a firm nudge should do it. I've never had any grinding from mine.
Old Sep 11, 2006 | 08:34 PM
Cormacs's Avatar
It's not soo much a grinding. It just sounds like gears rolling over each other. It's hard to describe. I noticed it can be a little difficult to shift between gears. Takes a little more then a nudge.
Old Sep 11, 2006 | 10:31 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
they do shift hard and sound kinda rough but that part is normal. grinding such as going from l.range to high w/out stopping isnt normal. the rpm range is right so its not because its idling to high. bring it to their attention and if they say it normal ask to see ( hear it) on another model so you can hear for your self.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
fredrikrosen
Sep 28, 2015 09:58 PM
r1pilot83
Sep 27, 2015 07:38 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
