Help servicing an '02 500 Rubicon
Old Sep 18, 2006 | 08:11 PM
kvrdave's Avatar
Default Help servicing an '02 500 Rubicon
Lost the stupid manual and I distinctly remember there being something about two plugs that needed to be removed for this. Generally I take it to the shop, but it is a long ways away, so I want to do it myself. Is there an online manual anywhere or something?
Old Sep 18, 2006 | 09:52 PM
angler's Avatar
Are you taking about the drain plugs for the oil? If so yes there is two drain plugs. You also have to take the skid plate off to get to the oil filter. Hope I helped.
Old Sep 19, 2006 | 02:46 AM
kvrdave's Avatar
I see one plug through a hole in the skid plate but not the other. Is the other one hidden behind it?
Old Sep 19, 2006 | 10:02 AM
VonEggBerger's Avatar
kvrdave, go to servicehonda.com and download the parts finder .pdf. Under Parts Group - Engine Section, look at the Oil Tank drawing. Bolt # 15 is the drain bolt. Then, under Front Crankcase Cover drawing, # 12 is the Oil Filter and Bolt. Also, it is highly recommended to replace the aluminum washer when changing the oil.
Good Luck
Customer Service #1
May 15, 2020 08:46 AM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
