1996 polaris sportsmen 400
Old Sep 19, 2006 | 09:10 PM
smurfette's Avatar
Default 1996 polaris sportsmen 400
My atv doesn't want to go into gear.It is a automatic.The idling seems to be high would that cause this problem.Please help.thanks
Old Sep 20, 2006 | 07:55 AM
ftwflh's Avatar
Too high of idle WILL cause it to not go in gear.
Old Sep 20, 2006 | 06:33 PM
smurfette's Avatar
Thanks,set the idling and it is shifting fine.Now i have another problem.Put a new starter relay and battery on it and when you try to start it it just clicks.Any idea of what it could be?Hope you can help.Also does it have a neutral switch.
Old Sep 20, 2006 | 09:55 PM
Instigater's Avatar
No neutral safety switches. "Clicking" can be caused by low batt(which yours is new), loose or poor connections is probably the cause. Check at all the connections that you messed with first. If it is not found, then look at the starter connections!
Old Sep 22, 2006 | 04:02 AM
mrtwostroke's Avatar
most likley cause is worn out shifter linkage. replace the tie rod ends on the linkage then readjust. and problem should go away. do this asap. or you will need a tranny teardown to replace the shifter dogs
Old Sep 22, 2006 | 07:55 AM
ftwflh's Avatar
Clean all the connections and if it stil clicks it is time to rebuild the starter motor.You can get a rebuild kit off ebay for around $40 just do a search for polaris starter
Ramman1
Aug 11, 2022 01:53 PM
GregM
Mar 6, 2018 06:53 AM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
GregM
Jul 29, 2015 09:41 PM
Countrygirl1976
Ask the Editor
Jul 13, 2015 12:19 AM
