problim with rancher
Old Dec 4, 2000 | 10:40 PM
400exdude's Avatar
i have a 200 rancher and if i use the choke on it and it gets warm and i go to shut it off i push the choke in and its like it never shut off its still idleing hight and i have to turn the idle all the way down ride for a couple mins then shut it off and re set the idle what is wrong with it?
Old Dec 5, 2000 | 03:18 PM
madmax's Avatar
Check your choke cable it sounds like its binding and not shutting and opening the choke
Plate correctly in the carb.
Old Dec 5, 2000 | 03:23 PM
snowshark's Avatar
The cable must be binding, haven't heard of this problem before. It wouldn't hurt to lube the cable a little.
Madmax, Where is Sumner? Where do you guys ride?
Old Dec 5, 2000 | 11:01 PM
1rancher's Avatar
400EXDUDE,
I had a similar problem with my Rancher so I took it to the dealer and the choke cable had to be replaced.
Old Dec 9, 2000 | 08:26 AM
cndrancher's Avatar
I've had the same problem with my Rancher, whenever the temperature would drop below freezing the choke would get stuck. It freezes right @ the carburator connections. This is what I'm not sure about, because it's friend that fixed it. He said since the choke is a plunger type he removed something in the carb. mechanism.
Good Luck Hope this was any help.......
vandammages@gmail.com
Aug 20, 2020 11:50 AM
Johnny Mac
Aug 15, 2019 03:13 PM
Clint Russell
Sep 25, 2015 03:20 PM
rgjackson
Sep 17, 2015 11:21 AM
Elkaholic
Sep 6, 2015 02:44 PM
