Hall Effect Sensor does it have to be changed??
Old Sep 21, 2006 | 11:40 AM
TLC's Avatar
TLC
Default Hall Effect Sensor does it have to be changed??
I have a 2001 500SP the speedo needle , trip meter and odometer do not work but the cluster and speedo lights and hour meter do work. My 4wd and reverse overide DO work. If I do not replace my Hall effect sensor does that just mean I live without a trip meter and speedo or should it be changed?
Old Sep 21, 2006 | 12:09 PM
ricknzep's Avatar
My 02 500ho speedo died after 6 months, then again just sfter warranty expired-the speedo's suck. my 4wd works great-that all i care about. the speedo's are expensive and as long as 4wd works then i don't care.
Old Sep 21, 2006 | 05:43 PM
colt2245p's Avatar
i have replaced mine 2 times and it did just as you explained yours. not that expensive a part but i like to keep track of my mileage.
Old Sep 22, 2006 | 03:57 AM
jimmypsp700's Avatar
I agree, I replaced two and my speedo hall sensor did the same thing before it stopped working all together.
Try cleaning the sensor at the rotor on the front right side first, if this don't help there is a testing procedure in the service manual or just get the $50 part
(model year 2002-03 Sportsman 700 p/n 4010298) and replace it yourself, it plugs into the back of the pod speedometer, easy fix.
Jim
vandammages@gmail.com
Aug 20, 2020 11:50 AM
bigbear350quad
Sep 11, 2015 12:40 PM
Randy Lee Frye Sr.
Sep 9, 2015 02:30 PM
poutlaw525
Sep 9, 2015 03:19 AM
Jason Campbell
Sep 7, 2015 02:25 PM
