2003 warrior starting problems
Old Sep 21, 2006 | 07:55 PM
zYamahaRider's Avatar
Default 2003 warrior starting problems
Hi, I have a 2003 warrior and i absolutely love it!! But the other day when i went to start it up i heard a spinng sound. The engine was not turning over but i heard the starter motor spinning. Is there some kind of one-way shaft or part that may have went bad???
PLEASE HELP!!
Old Sep 21, 2006 | 08:23 PM
recon99's Avatar
It sounds like your starter clutch (one way bearing). Like with most yamaha's, the one on the warrior is a common problem.
Old Sep 21, 2006 | 08:25 PM
Ok thanks, do you have any idea how much that part would cost and is it a do-it-yourselfer of would it be better off left to a mechanic. Any special tools needed?
Old Sep 21, 2006 | 08:57 PM
recon99's Avatar
The parts will be about $200 I think, because you will need the one-way assembly, and the gear that the bearing rides on, because the mating surface on the old gear will be pitted up and uneven. When mine went out I had my uncle fix it for me, so I don't know exactly what's involved with it. I think you will need a flywheel puller to get to the one-way.
If you want to take a look at a service manual for the warrior, let me know and i'll find you the link to download one for free.
njrider64
Jul 4, 2017 01:40 AM
Thanos
Jul 12, 2015 08:40 PM
Nelson
Jun 20, 2015 01:59 PM
mikey426
Jun 17, 2015 03:53 PM
1000gade
May 27, 2015 12:37 PM
