bayou 300 not running right
Old Sep 22, 2006 | 03:17 PM
Hillbillymudder's Avatar
Default bayou 300 not running right
i have a 93 bayou 300c and i didnt ride it for a few months and now when i start it up its spits and putters and when i give it gas it dies..it wont even idle correctly..can someone help?
Old Sep 22, 2006 | 03:59 PM
Hayashi's Avatar
More than likely old gas gumming up inside the carb.
Easy way first:
Drain old gas from carb and fuel tank, then run some fresh gas.
If that doesn't work, you need to remove the float bowl and clean out each jet and fuel passages with either thin wire or spray some contact cleaner. Need some real good carb cleaning. Also, check your plug.
Good Luck.
rcappie4
Jun 21, 2015 07:33 PM
jgreerberube
Jun 21, 2015 02:27 PM
momofo
May 27, 2015 12:06 PM
C.bailey
May 26, 2015 09:01 AM
Smokinthebear
May 7, 2000 08:01 PM
