bayou 300 not running right
More than likely old gas gumming up inside the carb.
Easy way first:
Drain old gas from carb and fuel tank, then run some fresh gas.
If that doesn't work, you need to remove the float bowl and clean out each jet and fuel passages with either thin wire or spray some contact cleaner. Need some real good carb cleaning. Also, check your plug.
Good Luck.
Easy way first:
Good Luck.
