02 sp600 speedo problem
Old Sep 23, 2006 | 04:03 PM
vbgagnon's Avatar
Default 02 sp600 speedo problem
Hey guys, my dad has an 02 600 and the speedo doesn't work. Everything is plugged in but it doesn't work. Any idea as to how this could be fixed?
Old Sep 23, 2006 | 04:08 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
chances are his awd doesnt work either right?
Old Sep 23, 2006 | 04:12 PM
vbgagnon's Avatar
I'll have to check that. I'm not sure. Do these problems usually coexist?
Old Sep 23, 2006 | 04:15 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
yes. usally when you loose your speedo you also loose the awd. they are electronicaly conected some how. better check it b4 he goes and gets stuck. if you do a speedo serch on here you will see serval post w/ the same problem and buying a new one is the fix i beleave.
Old Sep 23, 2006 | 04:17 PM
vbgagnon's Avatar
Thanks I'll do some diggin!
Old Sep 25, 2006 | 12:21 PM
motoman67's Avatar
check the halfax sensor on the right front brake caliper mount if its bad or the wires are broken then the speedo wont work its fairly common for these to go bad.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
