Wolverine ring and pinion
Old Sep 23, 2006 | 10:47 PM
dylan's Avatar
Default Wolverine ring and pinion
Does the wolverine have a ring and pinion setup, if so does anyone make different gear ratio set ups for them?
Old Sep 24, 2006 | 08:32 AM
LotusPosition's Avatar
I don't think so. Tires size is the only way to alter gearing.
Old Sep 24, 2006 | 01:49 PM
ATV_MAN's Avatar
There is different gearing for Wolverines but you have to tear into the trans to replace the 1st and 2nd gears. You replace them with Big Bear gears, which give a little more torque for low end. I'm not sure how or what exact parts have to be changed but maybe someone can elaborate a little more on this.
Old Sep 25, 2006 | 10:19 PM
dylan's Avatar
Maybe someday, if i can find some Big Bear gears like that i'll give it a try. would'nt the jump from a lower big bear 2nd gear to a higher wolverine 3rd gear be a little much, or isn't it that much of a jump? Thanks for the help
Old Sep 27, 2006 | 09:07 AM
GlennJ's Avatar
IMHO, it's not really worth it. I have a Wolverine and love it for what it is...it's a sport oriented 4x4. I ride with a lot of guys who have big bore 4x4 machines. I really don't have any issues keeping up or going most places they go. However, if I wanted to deep mudding, or get so stuck I need to winch out, I'd probably get a machine with more displacement and a locking front diff. Like I said, my machine is perfect for me, but I know it's limits.
Old Sep 27, 2006 | 11:42 PM
dylan's Avatar
The Wolverine has NO limits!!!!!
Old Sep 29, 2006 | 12:02 PM
GlennJ's Avatar
LOL! It's a great machine and I love mine...but it certainly can't do everything a big bore can do.
Old Sep 30, 2006 | 01:22 AM
SpDdEmOn's Avatar
No, you guys are almost right. The BB gears replace the Wolverine 4th and 5th, wheel gears and pinion gears in the tranny for more RPM drop in the higher gears which allows more top speed. A shift cam and segment will also be required in the swap. Overall I think you can do it your self for a little over $200. Back when I did it, I had about $220 in it.
Adam
Joe454
Nov 20, 2020 01:19 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
nastyblaster100
Sep 13, 2015 01:19 PM
bvolks
Sep 13, 2015 12:57 PM
Steeldon
Sep 9, 2015 09:38 AM
